tacho going wacko ea82
keppler
Post by keppler » Sat Jul 07, 2007 9:43 pm
while driving the tacho will just go springing back and forth by about 1000rpm it is also effected when i flick the lights on or the thermo's any ideas would be much appreciated :???:
schultzie
Post by schultzie » Sat Jul 07, 2007 10:01 pm
funnily enough i just installed my tacho, works fine untill i turn the lights on as well... whats the gos ppl
L-series Ea82t, WAIC+BOV 1Bar, 15's, 5sp dr, WOLF3D V4+, =D
keppler
Post by keppler » Sat Jul 07, 2007 10:23 pm
glad i'm not the only one
Post by steptoe » Sun Jul 08, 2007 12:39 pm
voltage regulator thingy on the back of the dash ?
vincentvega
Post by vincentvega » Sun Jul 08, 2007 2:05 pm
i thought this means your alternator was on the way out.. seen these symptoms in a few RX's with dead alternators
keppler
Post by keppler » Sun Jul 08, 2007 2:31 pm
just checked alt still putting in just over 14v
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Jul 10, 2007 2:11 pm
Generally menas the alternator is sad or the reg on the alternator is being bad like mine atm
The long road ahead
Wraith
Post by Wraith » Tue Jul 10, 2007 2:18 pm
alternator is toast, even tho its still putting out 14v
i have had this twice in different L's.
jumping tachos, flickering lights, stereo dropping in and out
both times fixed with alternator being replaced.
my 2cents
Destroy waves, NOT beaches.
1990 L Sportswagon (Mine)
1988 L Touringwagon (Hers)
1998 Liberty GX Wagon (Ours)
1987 L Touringwagon (SOLD!!)
1986 L Jap Import Turbo wagon (SOLD TO TIMMO!!)
1986 L RX Turbo wreck (SOLD TO TIMMO!!!)
Post by Gannon » Tue Jul 10, 2007 5:27 pm
could also be a bad ground between the dash and the chassis
schultzie
Post by schultzie » Tue Jul 10, 2007 5:39 pm
mine works when the lights are off but when i turn them on it plays up but if i put the dash lights up to full it works no worries again.. im guessing the tacho might be damaged,
Post by AlpineRaven » Tue Jul 10, 2007 8:22 pm
Happened to me once - it turned out to be faulty regulator (after 2 days ignoring it it went up to 17volts as it went off the voltage gauge and checked out whoa so i disconnected it and run off battery to auto electrician's) - I cannot remember how much, it was about 4 yrs ago and wasn't Subaru but it shows similar symptoms.
Pinch one from wreckers ;)
keppler
Post by keppler » Tue Jul 10, 2007 9:48 pm
thanks for your replys i have spare l series wagon to pinch one off to give it a go
keppler
Post by keppler » Tue Jul 17, 2007 10:38 pm
just changed regulator today still not any different any more ideas would be appreciated
Matatak
Post by Matatak » Tue Jul 17, 2007 10:48 pm
wt regulator got changed
i thought he wuld be meaning alternator sayin it went up to 17 volts etc
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
90brumby
Post by 90brumby » Tue Jul 17, 2007 11:43 pm
my tacho was doin this n then wat u no the alternator died
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by steptoe » Wed Jul 18, 2007 10:55 am
Didn't someone suggest voltage regulator (think that is correct term) on back of the DASH. pull dash out and on the board top left is a yellow thingy all on its own
Post by El_Freddo » Wed Jul 18, 2007 2:15 pm
jono wrote:Didn't someone suggest voltage regulator (think that is correct term) on back of the DASH. pull dash out and on the board top left is a yellow thingy all on its own
Is this a servicable item?
My low beams tend to do this little dimmer thing from time to time, sometimes i wonder if they're actually going to turn off and not come back on... fun times! Doesn't do it on highbeams either, only low beams.
keppler
Post by keppler » Thu Jul 19, 2007 9:09 pm
the little voltage regulator you are talking about is does it only regulate power to tacho? will it only be in sub's with a tacho?
because i have a spare suby for parts but it is dl wagon "no tacho"
Post by steptoe » Fri Jul 20, 2007 1:09 am
always had a auto electrician diagnosing this on various cars and fixing it by replacing it. dunno where he got his spares. he is now deceased
sven
Post by sven » Sat Jul 21, 2007 2:51 pm
had same problem with my first L-series post tacho dash conversion.
Everyone (mates, none of them auto-electrians) said after 10 seconds of careful consideration, 'bad earth' like they knew what they were talking about...
Put up with it for a while, hoping it would go away. It didn't
In the end, ran an earth lead from the instrutment cluster to car. Tacho problem fixed...'they' were right.
D'oh
