rear suspension silly idea?
Has anyone ever considered or looked at the feasibility of installing the complete rear suspension, crossmember and diff etc from a liberty or forester to an L series?
Could body mounts be added to the L series to allow this to be done? Or introduce a new custom made crossmember bolting to existing locations of the L series body while providing new fixings for the liberty stuff and simultaneously acting as a lift at the rear?
The logic being that if you do this to the rear and also change to Liberty struts at the front you get bigger brakes, 5 stud wheels and better rear suspension?
rob
rob
- vincentvega
- Brumby Boy
For what purpose? have you looked at the complexity of the lib readr end compaired to the L?
RIP 1992 Brumby
RIP 1992 Brumby
- stamp_licker
Ive seen pics of a Vortex on a Toyota chassis, with sloid axles and transfer case..... Anything is possiable with the right amount of time and money.
- brumbyrunner
Yeah it doesn't offer any upgrade for the rear end suspension wise. This is something I'm going to have to think about for mine too, how to beef up the rear end in the L.
Would the use of a lift kit help in lining up the rear end of the lib to the chassis of the L?
I've thought about the same thing when i saw a lib at the wreckers. Biggest problem is the cross member and the fuel tank (apart from lining up bolt holes etc).
Front end i havn't really looked at but reckon its outta the question too.
As already said, enough time and $$$$, anythings possible.
- Suby Wan Kenobi
Straight to the point, yes, it is a silly idea =)
It might turn out pretty good, but the amount of effort required to pull it off would not be worth it.
- Chris_Rogers
El_Freddo wrote:Would the use of a lift kit help in lining up the rear end of the lib to the chassis of the L?
front end is totally out of kilter. looked at this idea already. rear mount is no where near any of the mounting points.
