CV Shafts,.. what do you buy
Post by Gannon » Thu Jun 07, 2007 7:16 pm
I went to the local parts store and priced some new complete shafts, a whopping $250 each.
Im just curious where you get yours and what you pay for them?
Fang
Post by Fang » Thu Jun 07, 2007 7:21 pm
That is whopping - mine were $140 ea for complete MPFI shafts
Fatz
Post by Fatz » Thu Jun 07, 2007 7:23 pm
eBay-- or repco for my rx shafts.
i think eBay was 120 ea. and repco are 160 ea
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Jun 07, 2007 8:15 pm
We get em for $130 ea and they are new inner and outers
The long road ahead
julian
Post by julian » Thu Jun 07, 2007 8:22 pm
Where from may I ask?
Does having RX running gear mean I need a diferent part?
Anyone actually using the ones advertised on ebay???
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
Fatz
Post by Fatz » Thu Jun 07, 2007 8:32 pm
im using some from ebay.
id u are running RX gear then u will need a RX shaft which are 25 spline on the inner cup apposed to 23 for the N/A gearbox. Sadly part numbers are the same for turbo and non turbo shafts, ull just have to stress your point across that u need the RX shaft with the 25 spline inner cup. not the 23.
SUBYDAZZ
Post by SUBYDAZZ » Fri Jun 08, 2007 12:01 am
LOL whopping? Try a genuine part price ;)
SUBYDAZZ
LTurbo
Post by LTurbo » Fri Jun 08, 2007 12:41 am
Fatz wrote:Sadly part numbers are the same for turbo and non turbo shafts, ull just have to stress your point across that u need the RX shaft with the 25 spline inner cup. not the 23.
Your sh!tting me! the part numbers are the same? so they gotta take it out of the box/bag and count the spline grooves?
Fatz
Post by Fatz » Fri Jun 08, 2007 7:12 am
yup:P found out the hard way.
Ben
Post by Ben » Fri Jun 08, 2007 7:31 am
The ebay ones that come from Kempsey are crap, splines are loose and the cv's don't have a retainer ring = bad news if you have more strut lift than body lift.
Please watch before posting!
julian
Post by julian » Fri Jun 08, 2007 10:43 am
So avoid kempsey, otherwise quality is not much of an issue?
Julian
2004 Outback H6
2004 Forester XS
Ben
Post by Ben » Fri Jun 08, 2007 12:38 pm
yeah, ultracheapauto I think is their ebay id. Both myself and Gannon have had poor quality product from them. Also, the hole for the spring pin is too large and the pin falls through...
Post by AndrewT » Fri Jun 08, 2007 4:05 pm
Note that the MPFI shafts are also 25 spline (even tho its non-turbo).
Post by Gannon » Fri Jun 08, 2007 6:13 pm
Yeah, avoid Ultracheapauto.
I will try repco, although i want a FT4wd box, so im unsure if i should go out and buy new shafts for my carb box.
BTW, when i got those prices, there were partlistings for both carb (23spline) and MPFI/Turbo(25spline)
Fang
Post by Fang » Fri Jun 08, 2007 6:50 pm
Gannon - If you are putting an L Series Full Time box into a standard L (not an RX) and want complete shafts - you need MPFI shafts. Turbo and MPFI shafts differ on the outer cv i believe.
Ben
Post by Ben » Fri Jun 08, 2007 9:32 pm
Fang wrote:Gannon - If you are putting an L Series Full Time box into a standard L (not an RX) and want complete shafts - you need MPFI shafts. Turbo and MPFI shafts differ on the outer cv i believe.
Outers are the same no matter what, inners are different. For fulltime box he'll need RX inners. I believe that liberty inners will also work (anyone?)
Post by D3V1L » Fri Jun 08, 2007 10:03 pm
The only advice im gonna ofer is dont buy cheap **** :)....after going through 5 Cheap shafts in the matter of 2 weeks, then purchasing a good new $200 one i never had an issue again with it..
as the other have said...no retaining clip = disaster, kept tearing boots, all sorts of dramas.. The best will always be genuine subaru gear...but at the price i got over here in perth ($390 for a single LIB RS Turbo shaft), either u want quality or u dont...and i made the mistake not once but 5 times ...
dave
Fang
Post by Fang » Sat Jun 09, 2007 7:23 am
MechaWagon wrote:Outers are the same no matter what, inners are different. For fulltime box he'll need RX inners. I believe that liberty inners will also work (anyone?)
From my experience, If not buying the entire shaft, RX inners will not be enough. I have travelled this road. I had the RX cups ready to put into my L for my gearbox conversion (25 spline) - but the RX cups were too big too fit onto the ball of the standard L shaft. It must be my mistake about the outers however (apologies) - but unless I was given the wrong ones to start with - RX cups will not fit on the standard ball. I think Postie is also an expert on CVs now after his conversion.
(How are you mid-coast NSWers fairing those floods?!)
Post by Gannon » Sat Jun 09, 2007 8:50 am
Floods??? We've only had about 40mm of rain
Although a guy couldnt make it to tafe yesterday cos he was floodod in, he lives near Forster
Post by steptoe » Sat Jun 09, 2007 10:41 am
I can vouch for the RipEveryPoorCootOff shafts. They come with a 5 year 100,000km warranty. I have replaced each side three times under that warranty and have to put up a fight to get them replaced each time, the last time when it was four years old the smart arse then tries to tell me it is pro rata warranty, not 4 4WD, NO,
NOT ACCORDING TO COPY OF THE INVOICE , sir. So, phuc-q!
their supplier is national parts, as is autopro who sell 'em 20poocent cheaper ! don't think ap give same warranty.
not sure what crap I' buy next
