Pulley wheel keeps falling off
Post by Gannon » Thu May 31, 2007 6:24 pm
I have just rebuilt my ea82t and i cant get the crank pulley wheel to stay put, the bolt keeps loosening and falling off.
Has this happened to anyone else?
Should i use locktite? or maybe a spring washer?
Thanks
Ben
Post by Ben » Thu May 31, 2007 7:41 pm
Um, dude. your engine is running backwards if that is happening :lol
Please watch before posting!
90brumby
Post by 90brumby » Thu May 31, 2007 7:44 pm
put locktite on it aswell tho
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu May 31, 2007 7:46 pm
Are you doing the bolt up tight enough? Dunno weather i would use loctite as they can be pretty hard to undo normally without it.
The long road ahead
90brumby
Post by 90brumby » Thu May 31, 2007 7:49 pm
when we refit them at wrk we use locktite and do it up wid a rattle gun
Post by AlpineRaven » Thu May 31, 2007 8:14 pm
use red loctite - it'll do the job.
Post by Alex » Thu May 31, 2007 8:27 pm
yes i had this problem with my old EA...douse it in the strongest loctite you can get, and do it up sooooo tight. Get some mates the rock the car backwards and forwards whilst you tighten it..
mine only came off when doing doughnuts tho :D
Post by steptoe » Fri Jun 01, 2007 11:12 am
not finished mine yet !! but i found the roll pin was eating into the pulley making an oval pin hole so have redrilled two new holes and fitted two new roll pins to fit through into the timing belt cog on crank. I use silicone/silastic to hold these crank bolts from comng undone. Locktite and the like makes 'em real hard to undo if need be.
Post by El_Freddo » Fri Jun 01, 2007 2:17 pm
The way i do it is put the car in 4th or 5th gear, pull up the hand brake and use a breaker bar with the right size socket and pull until i can't tighten it anymore. Also works for removing the bolt...
Never had a problem with my crankpulley bolt coming loose using this method.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Jun 01, 2007 7:52 pm
I put a pin in the flywheel then tighten with a normal 1/2 drive ratchet and never had one come off as long as its pinned to the cam gears or to the crank it shouldnt come loose.
The long road ahead
Post by Gannon » Fri Jun 01, 2007 8:11 pm
Im not all that keen on loktite as i may wanna get it undone one day
What about a compression washer/ spring washer
Matatak
Post by Matatak » Fri Jun 01, 2007 10:02 pm
if you do it up to the correct torque (which is bloody tight) then i cant see a spring washer doing much except gettin squashed flat lol i thought they all had a huge washer on them normally anyway which can take the torque..
they shouldnt need locktite on them to keep them in if there done up enough
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
