Fitting up a manual boost controller on the ej20g is easy enough , just wanting to know what you do with the factory set-up , do you just plug all the hoses that are now open or disconect it all together, i would assume doing the latter that the ecu would spit out a an error code and think something was wrong.
Mike.
boost controller
Don’t run the factory boost solenoid or it will **** its self. just go from the actuator to the turbo. making sure to run the arrow (if its a gfb) to the actuator
Hunter S. Thompson
Hunter S. Thompson
- tim_81coupe
