trans cooler - fit in line with radiator ???
I have scored a trans cooler out of an EF Falcoon to stick in the GLTA.
Not sure if I should bypass the radiator auto cooler or include it.
Does tranny need the warmth of the radiator to warm up in first place at all?
it might pay me to read instrucions that come with new aftermarket coolers
- vincentvega
the whole point of the radiator end tank passthrough is that it does bring the auto box up to temp quicker, and then maintains it at that temp.
I have been told both ways, you should use the radiator because it will warm the box initially, and you shouldnt use it cos its just adding heat to the system.
not sure which way i will do mine.
yep, that's what i thought, a bit of ambiguity ! The cooler is factory so all I should do is copy what factory did, I'll check the donor radiator to see if it has the inbuilt cooler. Now might see if a falcon radiator fits before someone bags it !
Unsure if the auto even works as i have only been able to drive it 120m before the water cooling system over pressurised, and oil leaked all over the place - hope it wasn't tranny fluid.
When I had an Commodore that time, I used to use it for towing purposes and noticed transmission cooler does help.. What I did was I connected the output from transmission to radiator, and comes out from radiator to cooler then back to transmission. It wasn't good during cold startups but it does help while driving - Before driving off I always warm up anyway.
- stamp_licker
- vincentvega
I ditched the radiator all together with mine. seems to be fine, however you definately notice the extra volume of the oil system. you have to let the car idle for 10 secs or so to pump oil through the cooler and lines otherwise it will bang into reverse or drive
Well, so far so good. I ran the lines through between LH headlight and another hole to mount this cooler using zippy ties (too impatient to make bracket just yet) No leaks. Not yet driven it. I do recall reading factory stuff sayng fluid is also heated as well as cooled going through radiator. I guess warming it up through use will have to do. Thanks for reminding me to check the level (of both tranny dipsticks) The selector shaft seal looks like it has to be replaced from the inside !!! and it leaks
- stamp_licker
id say thru the rad aswell then into the outside cooler
thats the way it is done on my parents Pajero from factory
my dad wanted to disconnect it so if the rad ever comes out he doesnt lose ATF fluid and if the cooler was to ever start leaking then it wont be going into the coolant (ive seen it so many times on Falcons and Commodores)
but neway i made him keep it there as it dus help it warm up which is better for it and the outside cooler will kepp it nice if coolant temp ever rises (frmo 4x4ing or towing etc)
but still ya dont have to do it that way
Wagon is no longer....
