3d design program
Lapsed
3d design program
Post by Lapsed » Fri May 25, 2007 7:25 pm
Found this program by Google called sketch-up. http://sketchup.google.com/index.html
its relatively easy to use.
Made this mock up of a rear bar and tire carrier http://sketchup.google.com/3dwarehouse/ ... revstart=0. using the hard work of a bloke from http://www.ausjeepoffroad.com. Here is his write up of his efforts http://www.ausjeepoffroad.com/forum/sho ... hp?t=64441
and yes i hope to make something similar
this is a better version
chris
SUBARU OFF-ROAD RECOVERY VEHICLE
90brumby
Post by 90brumby » Fri May 25, 2007 8:04 pm
that looks pritty cool
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by El_Freddo » Mon May 28, 2007 11:08 am
I'm currently using 3d modeller and layout on the mac's at uni. I'm itching to make a model of my subi and do a 360 view of it but have to work on my folio first :(
and i've thought about making a 3d wheel carrier too - but you beat me to that one ;)
4xsama
Post by 4xsama » Mon May 28, 2007 5:27 pm
Anyone used Autodesk Inventor?
2000 Impreza RX
2010 Diesel Forester
Wraith
Post by Wraith » Mon May 28, 2007 7:49 pm
yeah, i use autodesk inventor 10 on a daily basis at work. top program for 3D modelling. In my opinion, the only better program i have used is Pro Engineer, which is quite amazing in its A.I.
my 2 cents
Destroy waves, NOT beaches.
1990 L Sportswagon (Mine)
1988 L Touringwagon (Hers)
1998 Liberty GX Wagon (Ours)
1987 L Touringwagon (SOLD!!)
1986 L Jap Import Turbo wagon (SOLD TO TIMMO!!)
1986 L RX Turbo wreck (SOLD TO TIMMO!!!)
Post by Alex » Mon May 28, 2007 8:38 pm
we use prosteel at work which is like an add-on to autocad, very very good prog.
theclick
Post by theclick » Mon May 28, 2007 8:46 pm
How do you change the units to metric in sketchup?
Lapsed
Post by Lapsed » Mon May 28, 2007 9:16 pm
Just found it. Go to the window drop down menu. click on preferences, then template. then it will give you a list of choices
chris
theclick
Post by theclick » Mon May 28, 2007 9:56 pm
awesome. thanks heaps.
looks a nifty little program. There a few problems with axis selection in perspective mode but otherwise quite easy to pick up :D
theclick
Post by theclick » Tue May 29, 2007 1:00 pm
got a wee bored thismorning on my day off uni so did up a mag :D not to scale at the moment, but would be easy enough.
very similar to sunny, but it was more of a excercise in learning
Ben
Post by Ben » Fri Jun 01, 2007 11:35 am
Now let's see you design a new EA82 head, turn it into G-Code, transmit to the 5 axis foam router and cast a new head :p
Please watch before posting!
