Help! My parkers won't turn off!
Problem fixed!
G'day crew. I went to drive my L series to work yesterday and the battery was flat, not totally but not enough to crank the thing. I had a look over the car and found that the parkers are staying on even when the ignition and headlight switches are both in the off position. Is this just a sticky relay and if so where is it located? I just moved so my L series manual is still in a box somewhere? Thanks, Marty.
- vincentvega
haahah so true! should lock this and make a sticky :Pvincentvega wrote:caught me out when i bought my car, and its always after you clean the interior
must have caught out 90% of the people on this board at some stage
Hunter S. Thompson
Hunter S. Thompson
First time this happened to me was after i had spliced the MPFI loom to the carbie one... I was wondering how i could f**k something like that up and i was pulling wires from the dash for a while before i realised the switch had been knocked when i was putting the dashboard back in... Glad it wasn't my wiring, i'd still be looking for the problem today...
My mate that also has this switch didn't care when i told him about it, his reply was something like "so why would i want to have my parkers on with the ignition off?" with an un-impressed tone that didn't warrant an answer.
that happened once when I first bought my Liberty, I accidentally left the parkers on overnight and had flat battery next day's lunch time.. lesson learnt!
gotta be careful too, on l-series in particular, the switch can sometime crap itself, and leave the parkers on, even if you switch it on and off, this is why i have totally by-passed this switch...
