Tough work for the old L
Moving Alex's new car...
750kg trailer + GX Liberty
- P31704421111.JPG (76.07 KiB) Viewed 4227 times
- tim_81coupe
- Captain Obvious
hmmmmm that would have been a little hairy what was wrong with using the black lib wags????
Actually the negative camber came back on my car...looks like it wasnt the rear end (swapped the entire rear-end over). I suspect the lift brackets for the rear shock absorbers may be bent or something now
The weight of the car on the trailer was forward but only slightly. It doesn't take much to make that much of a difference to the L series with its weak little shocks and springs. You have to have the weight slightly towards the front of the trailer like that, otherwise over bumps on bends it will lurch and take too much weight off the rear wheels and risk a jacknife.
Dave's Lib would also have coped fine, although his brand new clutch is very grabby so might have been abit difficult starting off at lights. Although lukily we got almost all greens on the way back.
andrews car did extremely well....highly impressed....just didnt look the best on the road with the ass end sitting on the ground
...and as andrew said, my clutch is a little too aggressive would have made things that little bit harder to do'
dave
dave
- vincentvega
Dude that was pretty dangerous.
Dave
Dave
hahahaha, not really..except for stopping i think..the L seemed very capable of towing even more!..that was easily a 2T load it was moving!
Nah its all good provided you keep the speed down and be careful. Somebody inexperienced tho...yes probably very dangerous!
Yeah....so are roof mounted spotlightsLightning_Silver_RX wrote:Not to mension illegal
That photo also makes it look way worse than it actually was. My wagon is just comming hard onto boost in 1st gear at that point, also going up a slight incline. Twas only a short trip.
Yer a legal debate on here would be a disaster. 3" lift kits....alot of our offroading locations.....most of our engine conversions.....lots of illegal stuff if you get into the nitty gritty.
[quote="AndrewT"]Yer a legal debate on here would be a disaster. QUOTE] lol some of us more then others.
