Remove window crank
Malc
Remove window crank
Post by Malc » Sun Nov 20, 2005 3:16 pm
Just wondering how to remove the window crank in the drivers side door in a Brumby.
Kev
Post by Kev » Sun Nov 20, 2005 7:05 pm
The window crank slides over a spline & is held in place by a circlip. The circlip can be pried off by a small screwdriver then the window crank can be slid off the spline. Be careful not to lose the circlip when it springs off.
To replace the window crank just put the circlip on the crank & slide it onto the spline. You will have to give it a wack with your hand to get it seated.
Kev
