Strange lift
Brumby Boy
Strange lift
Post by Brumby Boy » Thu Feb 08, 2007 12:50 am
Hay everyone,
I was having a good look at the underside of my ute particulary the lift kit to make sure we were fitting the one on my m8s brumby right, and i noticed that my gearbox crossmember doesnt have lift blocks as such. it looks as tho they have taken the gearbox crossmember out and cut the bolt hole out to almost two inches diameter and welded a 2" long piece of tube over it and then put a new plate on top then drilled a new hole in that plate to put the bolt through.
I find it strange that the gearbos is done like this and the rest of it is done with lift blocks like anyonter kit i have seen.
any insite into this would be appricated
cheers,
ian
RIP 1992 Brumby
brumbyrunner
Post by brumbyrunner » Thu Feb 08, 2007 6:25 am
I reckon this is a stronger method of spacing the radius plates. There is no extra surface to work loose and the bolts are nice short std length. All of my lift kits are like that.
Brumby Boy
Post by Brumby Boy » Thu Feb 08, 2007 10:10 am
cool thanks, it looks very profesional. but i thought it was strange only having the gearbox crossmember like this, its going to make it hard to take out to put in the bigger kit im thinking about getting unless i manage to track down a new cross member
RIP 1992 Brumby
daza
Post by daza » Thu Feb 08, 2007 12:49 pm
If it's the same as mine(sounds like it) then the Radius rod plates have the lift blocks welded to them, the gearbox crossmember is unmodified.
Daza
:D
Brumby Boy
Post by Brumby Boy » Thu Feb 08, 2007 12:53 pm
Maybe, ill have to have a better look (and get pics) next time im with my ute.
RIP 1992 Brumby
subgiraffe
Post by subgiraffe » Thu Feb 08, 2007 2:27 pm
Yeah, that sounds just like a boxer service kit that I put in my Brumby recently:
Brumby Boy
Post by Brumby Boy » Thu Feb 08, 2007 4:15 pm
Hay yea that does look just loke my kit actualy except mines been in 6yrs before i bought it
RIP 1992 Brumby
subgiraffe
Post by subgiraffe » Thu Feb 08, 2007 7:15 pm
did yours have lift blocks on the rear bump stops?
Brumby Boy
Post by Brumby Boy » Sun Feb 11, 2007 5:11 pm
I dont know about the rear bump stops but i had another look and yea it is the caster/radiuus rod mounts that are lifted. i didnt realise that the g/box bolts to thoes mounts not the body.
can you tell me, subgiraffe, if your gear lever sits foward since fitting that lift? mine sits foward and bashes on the head unit when selecting 1st or 3rd. im starting to think it needs new gearbox mounts and its not a lift problem
RIP 1992 Brumby
brumbyrunner
Post by brumbyrunner » Sun Feb 11, 2007 10:20 pm
Brumby Boy wrote:can you tell me, subgiraffe, if your gear lever sits foward since fitting that lift? mine sits foward and bashes on the head unit when selecting 1st or 3rd. im starting to think it needs new gearbox mounts and its not a lift problem
By all means check your gearbox mounts are ok first but this could well be the cause of the lift kit. Pull your gearstick out and bend it to suit your driving position and furnishings.
subgiraffe
Post by subgiraffe » Sun Feb 11, 2007 11:25 pm
If anything, my gear lever moved backwards. Hits the 4wd lever in 2,4 and R. You can bend the lever quite easily to make it fit..
Brumby Boy
Post by Brumby Boy » Mon Feb 12, 2007 1:30 pm
brumbyrunner wrote:By all means check your gearbox mounts are ok first but this could well be the cause of the lift kit. Pull your gearstick out and bend it to suit your driving position and furnishings.
I know the box mounts are rat sh!t, they are all colapsed, i dont realy want to go bending the lever if i can get away with it because its not just the gear lever, the transfer lever sits up i bit also.
RIP 1992 Brumby
