E95 Fuel kills my car
Post by Gannon » Tue Jan 30, 2007 4:43 pm
I filled up with E95 fuel the other day cos it was about 5c cheaper per ltr. I thought "meh, ethanol cant be that bad"
We (Girlfriend & I) drove to Dorigo and then to Ebor (which is about half way between Armidale and the coast. 1580m altitude)
Anyway,.. everytime i stopped the car, i would have trouble starting it. As in it would crank for nearly 10 seconds before it would fire, and when it did fire, it would only just idle, like less than 500rpm, i had to keep my foot on the accelerator to keep it running till i got moving.
At first i thought it mighta been the altitude, but everytime it wouldnt start, all i could smell was metho. Mighta been evaporating in the carby.
I put another half a tank of normal fuel and the problem has gone.
I will put pics of the mountains in the pics/vids section
Sorry for the longwinded post
subarursliberty
Post by subarursliberty » Tue Jan 30, 2007 5:20 pm
Same problem happened to me when I was young and owned a sigma. sigma was in perfect nick and as soon as I filled up on that junk it ran like every other sigma.
1992 Subaru Liberty Workshop Manual Complete
http://www.ausubaru.com/forum/showthrea ... #post58409
re-tune for new fuel type?
Post by El_Freddo » Tue Jan 30, 2007 5:24 pm
Maybe you need to re-tune the carb and/or timing to get it to run at optimum performance?
I've never known anything to change fuels and run 100% without some tuning for the new fuel...
Just a thought
PeeJay
Post by PeeJay » Tue Jan 30, 2007 6:36 pm
Would efi make it run better? I quite often use E95 in my Ej20t and it never seems to mind. Highest altitude I've ran it at was 1300m at 25deg.
cameron
Post by cameron » Thu Feb 01, 2007 11:36 am
Running ethenol in a fuel injected car is OK, as the computer will adjust for it. In a carby car set for petrol, the ethenol will make it run lean and hot.
If it can't be cut, welded or re-machined, you probably don't need it.
BlackMale
Post by BlackMale » Thu Feb 01, 2007 12:29 pm
- Is it Carb or MPFI?
- What’s “normal” fuel for you?
- Look at you tune? What is it set for?
- Did you know the fuel supplier? Possible ‘bad’ batch of fuel (a few of WA boyz avoid particular servo’s for this reason).
- Possible blockage coincidence?
Might be worth testing again… chuck in a small amount of 95% fuel from another servo when you tank gets low and see what happens.
Post by Gannon » Thu Feb 01, 2007 3:24 pm
She has a Carby
That is the second time that i have got e95 fuel from that supplier, the first time i thought that the car seemed a little sluggish
I normally get just normal unleaded. Its a shell servo.
