Alternator - worth rebuilding?
Alt outa a Lseries, so 55 or is it 60amp, half the rectifier is shot, maybe the regulator as well, brushes need replacing, windings measure ok,otherwise its pretty good, just looks and is 20yrs old.
So just wondering if its worth pursuing fixing it, what it may cost?
got a replacement that looks fairly newish for $70 at wreckers......
- waggaclint
Most altenator reco's use standard off the slelf parts(from specialists electronic shops) not geninune parts....
"Claudia"
"Claudia"
I went through the same last year, not worth rebuilding the old one.
Ended up buying a reconned one for $350, not cheap, but not an unknown from a wrecker that has no warrenty.
My local auto elec sells them. As long as the diodes are ok, that's all they really need. If you have been pulling big amps out of it, check the connecting wires between the top and bottom plates as they will 'unsolder' themselves. email me on [email protected] if you need pics.
If it can't be cut, welded or re-machined, you probably don't need it.
