Wanted to buy: L series factory steel wheels
geefish
Post by geefish » Fri Dec 05, 2025 12:41 pm
Hey. Chasing 2 x factory steel wheel for a 1993 GL wagon. Prefer here in Tasmania but may consider paying for freight if I can’t get anything local. Have contacted at least 12 wreckers here in Tasmania and there’s nothing about. Cheers, thanks.
Re: Wanted to buy: L series factory steel wheels
Post by El_Freddo » Sat Dec 06, 2025 8:41 am
G’day Geefish, which steel wheels are you after?
There’s the dull steel rims that aren’t real dressy and good for hub caps.
Then there’s the 8 spoke Sunraysia rims. Painted white from the factory. There are two version of these - early ones that came on the brumby that won’t clear the L series calipers due to the curve of the spokes.
You’d want the ones that are primarily flat with a tight curve in the spokes.
Return to “Wanted”
