Are there any reliable aftermarket parts as good as the genuine ones when it comes to replacing the wheel hub / bearing assemblies and drive sahfts, or are genuine parts still much more durable / better option even given the price difference?
Anyone with good / bad experience with either long term?
Genuine alternatives for hub/bearings and axle shafts?
Re: Genuine alternatives for hub/bearings and axle shafts?
Subydazz!! There’s a blast from the past!
If I’m not going genuine bearings I try to aim for a Japanese made bearing - NTN, Koyo etc
What are they going into?
Hi Freddo,
What are good value quality alternatives for CV shafts?
Thanks in advance
Thanks in advance
There really aren’t any - none as good as genuine OEM. No one wants to pay OEM prices though either!
So far Repco drive shafts seem to work pretty good for the most part. I have two on the front of the brumby, probably have 20,000km on them. I replaced a boot recently as it was spraying grease everywhere.
A mate of mine used to sell GSP shafts. Apparently they were bought out by some other mob and have since been merged with the new owner. Dunno if their quality dropped or not.
It’s a bit of a suck it and see. If you buy from online I doubt you’ll have any recourse for dodgy shafts that click pretty much out of the box. Buy from a store and you’ll have a better chance of getting a replacement - so long as you don’t mention lift. They might push you for evidence of a mechanic fitting the part if they’re trying to be picky. Just hold your ground and keep calm.
- Silverbullet
FWIW the best front and rear CV shafts I've had were genuine/original shafts that I nabbed from wrecker cars at U-pull it then got rebuilt locally at a reputable CV shaft specialist. Definitely not easy to tell if a shaft is genuine or not, sometimes they have ribs cast into the inner joint cup (for "cooling") sometimes one or two paint lines on the shaft section itself. The important thing is to have the inner joint type with 6 bearing balls as opposed to 3 bearing "tripod" style (junk) And of course for Brumby, the inner CV boot needs a 1 rib to be smaller than the rest to clear the steering column.
