Tribeca spotlights
- chubby37
Tribeca spotlights
Anyone know how to get spotlights hooked up properly on a b9 tribeca.i got them working but when I turn the headlights off they come on so I have to turn. Them off by the isolation switch I fitted .someone mentioned can bus or something...I just want to be able to leave the switch on and have them only work when I put high beam on....thanks guys
Re: Tribeca spotlights
G’day Chubby,
You’ll need to wire them in so they’re negative switched. That should do the trick!
