brumby drive belt
Engine, gearbox, diff & driveshafts
auster
brumby drive belt
Post by auster » Tue May 17, 2022 11:38 am
Can anyone help me with what is the correct fan belt for a 1987 Brumby, no air con?
About half a dozen possibilities show up on eBay but they are all different and only one can be correct.
Of course, I could take the existing one off and measure it. However I can't afford to have the car off the road and because it has power steering, getting the belt off is a more complicated job.
auster.
Subyroo
Re: brumby drive belt
Post by Subyroo » Tue May 17, 2022 10:06 pm
Have a look at the bottom of page 190 in this link - Gates Belts
Brumby 1982-94 AU5 1.6L 4 Cyl. 8v OHV Carb. EA81 Alt. & PS 11A0900.
auster
Post by auster » Thu May 19, 2022 4:24 pm
Many thanks
Post by El_Freddo » Thu May 19, 2022 8:35 pm
Good stuff Subyroo.
Auster, I was going to ask if your non AC EA81 had a belt driven fan or not as this also has an impact on the belt size.
You could remove the belt and take it into a parts store - some have one of those devices where you put the belt on to measure it. Obviously doesn’t do well with broken belts, especially if there are missing bits!
Post by Bantum » Wed May 25, 2022 1:40 am
Another trick is to get a bit of string or packing strap & wrap it around the belt path. It will give a good approximation of length without removing the belt. Pays to keep a spare of each belt in the 'kit' parts bin ... ;)
Cheers, Bantum ...
Return to “EA Drivetrain”
