Rankings ...
Ask for help from the Admin / Moderators ...
Rankings ...
Post by Bantum » Sat Nov 07, 2020 2:39 am
Another issue that comes up is the protocols of rank & their value ...
Rankings : ( Rank - Value ) Do note these are proposed values ...
  • Junior Member - 0 to 1000
  • General Member - 1000 to 2000
  • Senior Member - 2000 to 5000
  • Elder Member - 5000 to 10000
  • Master Member - 10000 to 20000
  • Grand Master - 20000 + Above
I'm thinking to revise ranking names / values ( Delete the onerous ones ) + Add new category : Grand Master ... :p
Thoughts ?
Ciao, Bantum ...
Re: Rankings ...
Post by El_Freddo » Sat Nov 07, 2020 9:54 am
Grand master should be master forum addict. If I put all post from every forum I’m on I would be well over that figure :???:
Re: Rankings ...
Post by El_Freddo » Sat Nov 07, 2020 10:01 am
I see someone changed some smily codes ^
I’ll get on the computer and see if I can sort out smilies with multiple codes. It would be good to get them useable with different codes for the same thing ;)
Re: Smilies ...
Post by Bantum » Sun Nov 08, 2020 4:40 am
Yer I noticed them too - Don't know how I managed that, as I was tweaking with a few settings to see if I could get the Sticky to work ... :mrgreen:
Re: Rankings ...
Post by Bantum » Sun Nov 08, 2020 4:45 am
So your saying you want an even higher figure ? ... :twisted:
Was thinking the rank should reflect AUSubaru values - not what's there currently, but open to suggestions ... :biggrin:
Ciao, Bantum ...
Re: Rankings ...
Post by Bantum » Sat Nov 14, 2020 12:30 pm
Ok - I've implemented the above changes, see what you think ... 8-)
We may need to adjust the values if they're not working for you ... :oops:
Add: I note there's a facility to add 'special' rankings that could be made for those wanting to be different ...
( not sure how it works yet )
Suggestions :
  • Operator Member
    Developer Member
Any other requests ?
Cheers, Bantum ...
Return to “Contact a Moderator”
