Front male driveshaft inner cup and C clip retainer pins
Post by El_Freddo » Mon Jul 13, 2020 11:38 pm
Hey all,
I’m after a used/dead inner front drive shaft cup that plugs into the gearbox.
I only need one.
I’m also chasing two of the retainer C clips from the end of the above drive shaft inner CV cup.
What I’m up to: adapting the 23 spline L series diff stub axles to fit into phase 2 EJ gearboxes. The stubs fit but need the C clips and groove to hold them in place. I need the male inter cup do measure the clip placement to mod my stub axles. (To make this work you also need the stub axle bearing “carriers”/tensioners to keep the oil where it should be).
Please let me know if you’re willing to send these bits my way.
Return to “Wanted”
