P2565 error
Crankshaw1
Member
P2565 error
Post by Crankshaw1 » Sat Oct 26, 2019 9:14 am
just started getting a P2565 error code.
turbocharger boost control position sensor a circuit high
Anyone seen this before?
Possible causes ?
Car = 2010 Diesel Forester, 207000km on the clock
Drives OK still.
Thanks
AUSUBARU ELDER
Re: P2565 error
Post by TOONGA » Mon Oct 28, 2019 10:59 am
Potential causes for this code to set are: Short to power in the signal circuit to the TBCPS sensor - possible Open in ground circuit at TBCPS sensor - possible Failed TBCPS Sensor - likely Failed PCM - unlikely
Read more at: https://www.obd-codes.com/p2565
Copyright OBD-Codes.com
Crankshaw1
Member
Re: P2565 error
Post by Crankshaw1 » Mon Oct 28, 2019 3:26 pm
Tanks Toonga, so most likely an electrical fault, will see if I can fin the senso and then check the wiring harness to it.
AUSUBARU ELDER
Re: P2565 error
Post by RSR 555 » Mon Nov 11, 2019 10:47 pm
At 207k, have you had any turbo or dpf work done recently? Is everything looking clean and in place around this area?
