just started getting a P2565 error code.
turbocharger boost control position sensor a circuit high
Anyone seen this before?
Possible causes ?
Car = 2010 Diesel Forester, 207000km on the clock
Drives OK still.
Thanks
P2565 error
- TOONGA
- AUSUBARU ELDER
Re: P2565 error
Potential causes for this code to set are: Short to power in the signal circuit to the TBCPS sensor - possible Open in ground circuit at TBCPS sensor - possible Failed TBCPS Sensor - likely Failed PCM - unlikely
Read more at: https://www.obd-codes.com/p2565
Copyright OBD-Codes.com
Crankshaw1
- Member
Re: P2565 error
Tanks Toonga, so most likely an electrical fault, will see if I can fin the senso and then check the wiring harness to it.
- AUSUBARU ELDER
Re: P2565 error
At 207k, have you had any turbo or dpf work done recently? Is everything looking clean and in place around this area?
