Power steering.
Aussyroo59
Member
Power steering.
Post by Aussyroo59 » Thu Aug 29, 2019 10:24 am
I changed the power steering belt the other day. Alternator pulley seems out of alignment using straight edge. After checking to be sure pulleys are tight l mustve overtightened th belt a little. Terrible groaning & ps fluid spewing from top of reservoir. Any knowledge will be helpful. Car is 2000 outback limited.
Aussyroo59
Member
Re: Power steering.
Post by Aussyroo59 » Thu Aug 29, 2019 6:04 pm
Power steering is fine now, so the difficult issue now is how to align the power steering & alternator pulleys. Thanks in advance.
AUSUBARU MASTER
Re: Power steering.
Post by El_Freddo » Thu Aug 29, 2019 7:41 pm
How far out of alignment is the alternator? Are we talking two or three mm, or more than 5mm?
Standard alternator or has it been replaced recently?
AUSUBARU ELDER
Re: Power steering.
Post by TOONGA » Tue Oct 22, 2019 9:48 am
moved from forum help to troubleshooting, as forum help is for help with the board.
AUSUBARU ELDER
Re: Power steering.
Post by RSR 555 » Mon Nov 11, 2019 10:31 pm
There isn't any adjustments to the alignment of the P/S pump or Alternator, so my thoughts are that if the pump and alt pulleys are inline, then the crank harmonic balancer is out.
