Another EJ22 and loom "bench" test
Post by El_Freddo » Mon Jun 10, 2019 10:15 pm
So, I'm at it again :mrgreen:
Here's my second EJ conversion first start up in my makeshift testing "facility", pretty much bang on 10 years since doing the one for Ruby Scoo.
https://youtu.be/vBXrmIzWiZY
And back in 2009:
https://youtu.be/CUjKbPrZDLM
Needless to say, I'm pretty happy with this result!
More on it later, probably in the appropriate build thread ;)
Re: Another EJ22 and loom "bench" test
Post by TOONGA » Tue Jun 11, 2019 8:43 am
Bennie nicely done I have to do this to an EJ18 eventually.
I will probably go this way if I can find a broken gearbox
(not my image)
If not I have a box sitting on the ground here I can bolt my engine up to
Post by El_Freddo » Tue Jun 11, 2019 12:16 pm
Thanks mate.
My only concern with mounting the starter like that is you expose the flywheel. I can be a little OHS over the top at times but I think it easy to overcome. Plus you’d need to have an eight bolt engine for this to work, or shave the bell housing down to include the lower stud.
