K&N air filters - are they better than OEM?
Jack
Post by Jack » Thu Dec 21, 2006 7:51 pm
Does anyone have any experiences with using a K&N filter? I've been advised that fitting one to my Outback (EJ25) would be more economical in the long term and improve airflow. I don't know anything about K&N except that they're supposed to last a long time and they cost around $110 each.
Here are some pics I found while Googling.....
This is what it's supposed to look like from the box. Info I found says that the correct size for my model Outback (MY99) is 33-2154.
This is what an Outback's filter box looks like.
Apparently inside the K&N packaging is this Gucci looking sticker which is supposed to remind people not to throw the K&N filter away.
Any info would be appreciated.
Jack
1999 Outback (some mods)
1989 Brumby (more mods)
cameron
Post by cameron » Thu Dec 21, 2006 8:33 pm
They flow better and give better response. Cleaning and reoiling is a lengthy process. I've used them, but prefer the oiled foam type as servicing is easier. Check out the O2 rush or Unifilter products.
If it can't be cut, welded or re-machined, you probably don't need it.
Post by Subafury » Thu Dec 21, 2006 9:38 pm
i reckon theyre awesome. even when my pod hasnt been cleaned n oiled for ages- which is easy to do- it still traps loads of fine sand and stuff. and yeh u save money by never having to get another filter.
fredsub
Post by fredsub » Fri Dec 22, 2006 7:09 am
the oiled foam type aka Unifilter didn't last a very long time, and you have to be delicate with cleaning them, and easily leave a mess if over oiled.
Have the K&N now, much happier with it,i bet it will last "forever", The K&N filter is supported in a grid, much more robust for cleaning, even if it does take a lil time - but its only like once a year anyway. They all save on chasing paper filters.........
waggaclint
Post by waggaclint » Fri Dec 22, 2006 8:01 am
K&Ns are good hey just as long as you maintain them they will last foreva hey good air cleaners.....they pay for em selfs in the long run cause you dont have to replace as often...
2011 Forester X
Jack
Post by Jack » Fri Dec 22, 2006 9:36 am
Thanks for the replies. What's the best way to clean and re-oil a K&N filter?
Jack
waggaclint
Post by waggaclint » Fri Dec 22, 2006 6:38 pm
with proper k&N cleaner and oil.....you should be able to get it were you get the filter from
2011 Forester X
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Dec 22, 2006 11:56 pm
Just remember not to use too much oil as residue on the AFM wires will give you head aches.
The long road ahead
Jack
Post by Jack » Sat Dec 23, 2006 9:18 am
Suby Wan Kenobi wrote:Just remember not to use too much oil as residue on the AFM wires will give you head aches.
Dave, thanks for the tip. I'll keep it in mind, but I usually listen to CD's while driving.
Jack
Post by Gannon » Sat Dec 23, 2006 10:22 am
Jack wrote:Dave, thanks for the tip. I'll keep it in mind, but I usually listen to CD's while driving.
Jack
You're funny :D
AFM = Air Flow Meter
AM/FM is the radio
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Dec 23, 2006 10:52 am
There is always someone who get into the Christmas cheer a little earlier than others.
The long road ahead
