Lseries tacho dash
- waggaclint
Lseries tacho dash
will tacho dash bolt straight in to Lseries and work or do you have to wire it up as such....this is on an carby model.....any help would be good cheers clint.....
2011 Forester X
As Fang said - the plugs are different. One of them should be the same in size and (guessing) the wiring as it is for the centre light panel (4wd lights etc) and the other will be for all the other stuff (indicators, gauges and taco). You may have to run two new wires to the coil as well. Check out the tech manual and see if there's anything in there. Other wise someone here who has done it will have more info. (i changed a whole loom and got a taco plus MPFI)
Hope this helps some
I think the two centre indicator panel plugs (doors, 4WD, Lo etc) are different. There are also two round plugs that plug in for fuel, lighting etc. We had to swap the wiring between these four plugs. Bennie is right - you do need to run a lead to the coil.
To get mine installed we used the plugs from a tacho model wiring loom and spliced into my DL one.
