dodgy spotlight wiring
Post by Subafury » Thu Oct 26, 2006 12:08 am
ive just spent the las 2 hours tryin to suss out the high beam wire for my new spotties.
my wiring(apart from that one wire obviously) is 100% and been double checked.
i connected to the topmost one on the globe terminals and this is what happens:
no lights on: spotties on
lights on: spotties off
high beam on: spotties on
wtf is goin on. with the circuit tester experimenting, i cant find the right wire to tap into. anyone else had this problem?
BrennyV
Post by BrennyV » Thu Oct 26, 2006 12:55 am
thats the one son, just make sure u run a relay and a switch.
Hunter S. Thompson
timmo
Post by timmo » Thu Oct 26, 2006 8:48 am
Yeah subi this is what I found aswell. When the headlights lights are switched off the power returns to the +'ve, so you just have to remember to switch your spotties off separately. I think the high beam circuit is broken by there being power to the -'ve aswell when the headlights are off. But at least when you turn the key off the spotties should go off. It was freaking me out aswell for a while when I was wiring mine up - different to other cars that i've put lights on.
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
Post by El_Freddo » Thu Oct 26, 2006 11:51 am
I second timmo.
Mine do exactly the same thing. It also happens on my girlfriends VT. I've just learnt to turn off the spotties before i turn off my lights... there must be enough of a current to trip the relay to switching the spotties on... generally speaking my lights are on all the time anyway, i only turn them off if i notice their reflection on the back of another car at the lights.
I'm sure there's a wire to the hi-beam realy that can be tapped on the signal side (when you flick to high-beam) possibly near the stalk itself... this is on my "to do list"
Happy hunting
Xtreme_RX
Post by Xtreme_RX » Thu Oct 26, 2006 12:55 pm
Subaru Headlights are + (Positively) AND - (Negatively) Switched.
You need to make the relay positive switching, not negative.
I.e. The relay is trigged by the high beam being turned on.
http://www.subiparts.com.au
0438 887 746
Post by Subafury » Thu Oct 26, 2006 4:42 pm
good so its not just my car hah
yeh ill have to have a hunt up to the stalk and see what i can find.
i can see myself leaving spotties on in the daytime if i dont.
bloody subaru wiring :p
BrennyV
Post by BrennyV » Thu Oct 26, 2006 6:35 pm
i neva turn my lights off?? best part bout a subi ;)
Hunter S. Thompson
SuBaRiNo
Post by SuBaRiNo » Thu Oct 26, 2006 8:14 pm
Bring it over Matt and i will sort it so it works properly.
Dave
Post by AndrewT » Thu Oct 26, 2006 9:28 pm
Subarino is da man, he'll sort it.
Funny stuff this Subaru wiring...Tim was telling me recently about a guy who got his EJ wiring cut down for his conversion by some dodgy guy... Aparently it was outputting engine error codes through the electric Thermo fans!!
***sorry for stealing the story Tim*** :p
SuBaRiNo
Post by SuBaRiNo » Thu Oct 26, 2006 10:03 pm
P.S... that dodgy wiring dude was not me.
Dave
tim_81coupe
Post by tim_81coupe » Fri Oct 27, 2006 7:02 pm
Pick up the power for the relay through the high beam wire, and earth the relay through the high beam / headlight earth rather than to the body.
Same thing happens on new Hiluxes, Kluger's, Taragos and 100 series Sahara (not STD or GXL.... wtf?).
All of which I've fitted spotties to at some time or another.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
wagonist
Post by wagonist » Sat Oct 28, 2006 1:45 pm
Ditto.
& you'll find different Toyotas work differently depending on whether they have the ignition off/door open triggered lights, or just on. ;)
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Post by Alex » Sat Oct 28, 2006 9:46 pm
that helps me heaps as well!...(my car does the same obviuosly)
cheers guys
