what coil for an EFI L?
artrixx
Post by artrixx » Wed Oct 04, 2006 11:15 pm
whats a good coild for an EFI l-series wagon. i have an annoying little stumble in 1st gear and im thinking it may be coil or leads so i thought i would see whats the best opinions on what particular coil would be the best for my car. cheers.
one more question i have a nice exhaust system from a carby L thats a larger diametre than the standard am i correct in asssuming that i could swap them over as long as i sort out the ..........BUGGER CANT REMEMBER ITS NAME !!! the sender on the xhaust . does this make sense???
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Oct 05, 2006 8:00 pm
You will need to put the oxygen sensor back in the carby pipe.
Any coil as long as it isnt one you use with a ballast resistor.
The long road ahead
