disabling/removing steering airbag
G'day..help needed removing or disabling on a Subaru momo wheel,Im worried if ill unscrew the 2 torx screw on the side, bag might pop out.what is the best option? cheers
I beleive there is a fuse or some wires you can cut which will disable it.
Why would you want to disable it tho?
- waggaclint
if your just removing it and putting it back on....just disconnect the battery and wait for 5mins and you can pull it off then without it going off....
But if your not sure id get a mechanic to do it for ya....
use caution if ya gonna do it your self as they can be dangerous if ya dont no what ya doing....
2011 Forester X
I changed the standard airbag wheel on my Toyota to another factory leather one using the original airbag.
Step by step:
Step by step:
- disconnect battery (not 100% necessary, but a bit of a safety recommendation)
- remove the plastic cowling around the steering column
- identify the plugs that go to the airbag part of the wheel.
These will run from a round plastic piece behind the wheel down. They will look different because there is a spring loaded part - undo these plugs. I'd suggest from lying on the floor & wear some hearing protection just in case.
The plugs have extra pins in them so that when they are undone, spring loaded bits touch the other normally active pins to help drain the static. - walk away from the car & leave it stand. The recommended time for the static to drain is 30 minutes, but I'd add a buffer just to be safe.
- undo those torx screws you have mentioned before
- gently pull the airbag assembly out
- there will most likely be another plug or 2 hidden behind the bag which will look the same as those previously undone. Undo these now.
- put airbag assembly gently to one side
- remove steering wheel as per a normal one now.
Installation is the reverse of dismantling, though you don't need the static drain period.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Previous rides:
