L series clock help (RX turbo)
I haven't removed mine yet, but if there are any electrolytic capacitors on the board, try replacing them too. They are notorious for drying out.
Clock fix
This resistor is in the supply (probably for a Zener diode) and gets hot.
Eventually leads to solder failure.
Resoldered and is now perfect....
- L series clock.jpg (89.36 KiB) Viewed 6606 times
I have a high res version of the pic but can't read the exact ohm value written on the pcb. It's definately 2 Watt, and has 820J stamped on the resistor (820 ohm???). You could try a 1K 2W or maybe someone has a clock laying around the garage that they read the value from?
There is one resistor that always burns out just wack a bigger wattage one in the porblem goes away.
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc. Offically now part of the 350, 000 km Club! And still pulling like a freight train.
"Claudia"
"Claudia"
Re: L series clock help (RX turbo)
FYI, the resistor value is 750 Ohm, 2W.
L-Rex
1992 L-Series Wagon, which used to be EA82 auto.
I'd just like to point out 11.75 years is an awful long time to wait for a reply (and one of, if not the, longest I've seen on a forum anywhere)!
Patrick
Ex- 2010 Forester Diesel
I don't believe in rushing things...
L-Rex
Of course not- all good things take time. Especially on a clock thread!!!
Patrick
LOL. I see what you did there, and I'm back for seconds...
L-Rex
Seconds... Hang on a minute, I could go on for hours...
Patrick
I had better watch what I say next...
L-Rex
