Gbox Ratio?
Gbox Ratio?
Where can I find the ratio of the Gear Box? Can't find a sticker anywhere, is it stamped into the metal somewhere? EA82 5spd dual range.
Smokey.
Smokey.
As I'm sure you're aware, there were two different final-drive ratios available in your model, 3.7:1 and 3.9:1.
As for being stamped on the gearbox, it's not that I'm aware of; However your rear diff should have a sticker on the cover that states the ratio. Front final drive will match the rear in your model.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry
Jibs
- Suby Wan Kenobi
