What Ignition Coil do i use??
Xtreme_RX
Post by Xtreme_RX » Fri Aug 04, 2006 3:58 pm
Ok guys I am in need of a new coil for my EA82T.
What type do I fit GT40R, GT40?
Or can I use a transformer ie. GT40RT?
I was thinking of using the GT40RT but Bosch says it’s only for point style ignitions not electronic like the EA82T uses.
Thanks.
http://www.subiparts.com.au
0438 887 746
bluesteel
Post by bluesteel » Fri Aug 04, 2006 4:16 pm
tim_81coupe
Post by tim_81coupe » Fri Aug 04, 2006 7:19 pm
I'm using a GT40RT on my EA82 with an electronic dizzy. I was using it before that on my EA81 points dizzy. Haven't had any ignition problems with the EA82 to date.
You will need a GT40 with an R, these are for use with a ballast resistor, which your car should have. So its down to GT40R or GT40RT.
However reading the testimonies of the MSD Blaster 2 coil from several members of this forum convinces me this is the better option. If I ever build another EA powered car (unlikely) I'll be fitting one of these.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
fredsub
Post by fredsub » Sat Aug 05, 2006 11:19 pm
I read he says he got a ea82t, so there shouldn't be a ballast resistor at all.
Ballast R is only required on mechanical points type distributor.
OEM coil is really good tho, you sure its toast?
Anyway, the MSD blaster is really good :p, GT40 coils are really very average coils........
MUDRAT
Post by MUDRAT » Fri Aug 18, 2006 5:46 pm
Used an Accel SuperCoil for years on both my L and MY and loved it.
