what oil to use?? ticking lifters?
hi carb ea82 l series wagon i cant find or remember what oil was used to clean these bloody ticking llifters...
anyway diesel fuel and or diesel oil? and possibly atf (dexIII)
and finally what oil has/ do people use after they have cleanded the lifters??
cheers Ben
cheers Ben
I did the diese fuel and oil trick with my car and yes it did clean some gunck out of the engine. unforytuneatly it made the ticking far worse.
i eventually had the oil pump rebuilt which has solved the problem by about 95%. still ticks when cold but nowhere near as bad.
If the ticking comes and goes suggest rebuilding oil pump .otherwise a good cleaning agent and a good quality thin oil may help eg. 10/40 grade, even lower still in tassie this time of year
- stephendean
i use shell helix for older engines, i know its pretty thick, and it has reduced my lifters from going crazy...also try some of that stuff which reduces lifter noise, cant remember what its called, but it helps heaps.(it comes in a black bottle and is usually around all those other octane boosters and stuff)
- Suby Wan Kenobi
