Post
by tim_81coupe » Tue Jul 18, 2006 11:15 pm
MY and L series have different outer CV joints. Same basic design, but if you put the two side by side you'll see the differences.
Andrew you'll need to replace that CV asap (duh) and you can't do the outer joint only trick unless you don't like your centre diff. That one only works on the part time boxes.
I did have one kicking about but I think I've binned it. It was suss anyway, having come out of my brother's car at one stage. I'd still have the inner CV and axle somewhere though, not much use to you atm.
If you want I can make some calls tomorrow... I will ask anyway and get back to you.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
