Aux Driving Lights
maddog
Aux Driving Lights
Post by maddog » Fri Jun 30, 2006 8:26 pm
88 L Series Touring Wagon - Can anyone tell me which signal wire to use when wiring up my auxiliary Driving Lights so that they only come on with Main Beam?
Thanks. :?
chubby37
Post by chubby37 » Fri Jun 30, 2006 8:35 pm
its in your colum plug...the big one....turn key on till dash lights show....use a test light as you turn hi beam on till you find the wire....will only power with hi on.....them hook your wire to it
SuBaRiNo
Post by SuBaRiNo » Fri Jun 30, 2006 8:51 pm
It's usually easier to find the signal wire from the back of the head light... then there are only as few wires u need to test.
Dave
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Jul 02, 2006 11:00 pm
If you pick up the signal from the back of the headlight you use the 2 outer wires as signal wires to the relay. Should you want to make it switchable loop one wire back to a cabin switch.
The long road ahead
maddog
Post by maddog » Thu Jul 06, 2006 8:00 pm
Thanks Guys - I'll have another go this weekend and keep you posted! 8O
