I've just replaced a crappy old radio-cassette with a new el-cheapo one. I now hear engine static through the speakers so I assume I need a suppressor somewhere in the circuit. Do I put one on the power line to the unit, or in the engine bay (positive terminal of the coil) or where? And does it go in series or parallel?
Hope someone can help and thanks in advance.
Engine static on new sound system
cheaper stereos are really prone to noise
you could try a couple of those small supressors on the alternator, coil and one on the actual stereo
there is also bigger ones that you can chuck inline with the power wire, but i havent had much luck with them
but 9 times out of 10 the problem is the last thing you changed eg you had no noise before and now you do so it could just be the new head unit
It's true crappy stereos are more common to interfearance.
Is the static like a cliping or ticking noise? or is it more of a whine with engine speed.
Clipping would be a sign of either the leads and the coil or something.... whinning would be alternator... filters rarely fix these problems. Buy a name brand deck and u should find it all goes good.
Dave
Dave
- tim_81coupe
