just only contemplating at this stage manual steer rack instead of power
[ Potential Oil Woes Every Reason ] I am betting the steering column hook up is same, but tie rods different with racks maybe ?
anyone done a power to manual L convert ?[/u][/b]
L Series Power steer to manual , easy ?
Rack
The mounting brackets that hold the rack to the crossmember are different as is the uni joint between the rack and the steering column. Otherwise all is the same.
