Hi all,
Does anyone have a wiring diagram showing the pinouts from the MPFI dash?
I'm looking to pick up the VSS signal from the reed switch...
L-Series VSS signal MPFI
L-Rex
1992 L-Series Wagon, which used to be EA82 auto.
Re: L-Series VSS signal MPFI
I'm using it and it works a treat.
Check out the EJ into L series thread in the conversions page, it's detailed in there. I'd link it here if I was on the computer, but I'm just returning from the bush
Is there no attachment upload anymore?
According to my diagram, its the Yellow/red wire at the back of the instrument cluster. It is also at the black 21 pin plug under the dash (there are 3 big plugs grouped togerther, white, black and blue) on the body side of this plug it is Yellow/green and is also the Yellow/green wire at the "check connector" behind the drivers side strut tower
