I am looking for expressions of interest in EA82 rear disc setup(s). I have been rebuilding a few sets imported from the US.
Indicative selling price will be $500 (note this does not include rotors, which would need to be sourced locally through eBay, SCA, etc), based on my costs :
$150 US - parts
$125 US - shipping of above from US to AUS
$25 US - parts (seals, etc)
$40 - plating
$20 - bead-blasting materials
$20 - primer, paint
$40 - incidentals (eg. fuel, valve caps, packaging, etc)
Each set has been :
Hubs : De-studded, wire-wheeled, masked, primed and three coats of high temperature black enamel paint on both sides. Studs were re-threaded or replaced, chemically treated, wire-wheeled, freshly zinc plated, and pressed (using a hydraulic press) back into place.
Backing plates : Straightened (they are always bent), wire-wheeled & bead blasted as necessary, primed and three coats of high temperature black enamel paint on both sides.
Flexible brake lines : De-greased, wire-wheeled on ends, chemically treated and zinc plated.
Calipers : Pulled down, wire wheeled and bead blasted, zinc plated. Pistons hand-polished and inside of pistons wire-wheeled and painted (zinc plating will not travel down into cavities so painting is the best option). Sliding pins and attaching bolts (one hex head, one allen-key head per caliper) also wire-wheeled (ends only), chemically treated, zinc plated. Bleed valve same as sliding pins. Calipers then re-assembled with new seals (piston seal, piston boot, sliding pin boots, valve bleeder caps) and new stainless shims. All bolts have anti-seize applied.
I can include pads (used) if you want.
Options (costs dependant on options selected) : Zinc backing plates, zinc backing plates painted (standard is just painted, not plated then painted), calipers painted (your choice of colours).
PM if interested. Delivery will vary from immediate to 4 weeks. I will have 4 sets available (it has taken me almost a year of searching to put them together).
If you want to post to say you can (or did) buy EA82 rear discs for $50 from a wrecker in 1992, don't bother. I know what they're worth - the few sets that are available through dedicated Subaru wreckers have asking prices of $500-600, and have 30+ years of rust on them with split boots and need the same amount of work as I have invested in these.
									EA82 rear discs
			EA82 rear discs
Post by dfoyl » Sun Dec 24, 2017 4:14 pm
				Jump to
	- AUSubaru Forums
 - ↳ Subaru Chat
 - ↳ Member's Area
 - ↳ My Subi
 - ↳ Photo Gallery
 - ↳ Videos
 - ↳ AndrewT
 - ↳ Bantum’s Works
 - ↳ Brumbyrunner
 - ↳ Brumby Kid
 - ↳ El Freddo
 - ↳ Guyph
 - ↳ Rumbl1n
 - ↳ Subie Boys
 - ↳ TOONGA
 - Model Specific Workshops
 - ↳ EA Drivetrain
 - ↳ EA Interior
 - ↳ EA Body, Paint & Exterior
 - ↳ EJ Drivetrain
 - ↳ EJ Model's Interior
 - ↳ Body, Paint & Exterior
 - ↳ Conversion work
 - ↳ SVX Specific
 - ↳ Drivetrain
 - ↳ EE series Drivetrain
 - ↳ EE series Interiors
 - ↳ FB/FA Drivetrain
 - ↳ FB/FA Interior
 - ↳ JDM Kei Cars
 - ↳ Kei car Drivetrain
 - ↳ Kei car Interior
 - ↳ Other Subaru Car Projects
 - ↳ Bike Projects
 - ↳ All things Boats
 - ↳ Subaru Planes
 - Workshop Studios
 - ↳ Tech Manual
 - ↳ Trouble Shooting
 - ↳ Engine, Gearbox and Diff
 - ↳ Intake & Exhausts
 - ↳ Security - Locks & Alarms
 - ↳ Brakes, Wheels and Tyres
 - Classifieds
 - ↳ For Sale
 - ↳ Wanted
 - ↳ Subaru OEM / NOS Parts
 - Your Area
 - ↳ Queensland
 - ↳ Subaru 4wd Club of QLD
 - ↳ Club chat
 - ↳ What's on
 - ↳ New South Wales and ACT
 - ↳ Victoria
 - ↳ Western Australia
 - ↳ South Australia
 - ↳ Northern Territory
 - ↳ Tasmania
 - ↳ New Zealand
 - ↳ PNG & Pacific Islands
 - At Play
 - ↳ Product Reviews
 - ↳ Communication
 - ↳ Camping and Travel
 - ↳ Navigation
 - ↳ Fishing
 - Off Topic
 - ↳ Sandbox
 - ↳ Open Slather
 - Forum Feedback & Contact
 - ↳ Forum Help Area
 - ↳ Contact a Moderator
