Subaru Vortex Differences
Hi guys
I am about to buy a Series 1 Vortex and just want to know if I can put all my running gear eg: Engine, Gear Box, Diffs etc.. from my current 87.5 Serioes 2 to the new one as the Series 1 is Non Turbo, Auto and FWD.
All I know is that the body is the same and just want to know if the engine and all the bits will just be a straight swap.
If anyone can let me know as soon as possible it would be highly appericated.
Best Regards
Johnny T
Best Regards
Johnny T
Johnny T
88kw of fun waiting to happen
Johnny T
- Bantum
Fitting ...
From what I've read / seen - All the drive train stuff should fit, but the old FWD series I may not have all the mount points for the 4WD rear end - Only one way to find out - try it & see ...
Cheers, Bantum ...
Cheers, Bantum ...
if its fwd it wont have the captive nuts or holes for the rear mustache bar mounts.
i have done fwd vortex to awd previously and just drilled the holes in the correct location underneath the car. its already marked where the holes need to go.
A slightly bigger hole is needed above (in the boot) to drop a bolt through/hold on to with socket when tightening.
Thanks for the advise Bennie,
I’m going to try this weekend to get my turbo engine from the Series 2 running and then start transferring everything over the weekends with my mechanic
and yes it was the Green body with the brown interior and that will be swapped over with my sprayed black interior. I will be taking photos of the build and posting them up, just didn’t get a chance this weekend to get any photos.
Kind Regards
Johnny T
Kind Regards
Johnny T
Johnny T
Johnny T
