leone 89 new stereo HELP
Get wild & funky with your Mobile disco ...
outback_98
Post by outback_98 » Thu Mar 09, 2017 6:37 pm
How do you wire at new stereo in,had it working but only if the headlights were on :/
Research ...
Post by Bantum » Fri Mar 10, 2017 5:17 am
I'd get hold of a wiring diagram for your year model + the head unit pin outs - should then be a matter of finding all relevant wiring & match them up.
Depending on how you want it to work, most units require key in ignition - turned to the accessories position to work. ( secondary power for clock )
So def' something amiss with it only working on headlights ... :/
Plus there's heaps of 'help threads' out there to read up / search on the subject too ... ;)
Ciao, Bantum ...
Post by TOONGA » Fri Mar 10, 2017 4:22 pm
this is the wiring for 1990-93 Subaru Loyale Stereo Wiring
from http://www.decibelcar.com/stereo-wiring ... ubaru.html
Permanant 12V+ Red/Green
Accessories 12V+ Blue/Yellow
Ground - Black
Illumination - Red
Dimmer N/A
Antenna Location N/A
Front Speakers 6 1/2 Doors
Front Left + Yellow
Front Left - Blue/Red
Front Right + White
Front Right - Blue/Black
Rear Speakers 6 1/2 Rear Deck
Rear Left + Yellow/White
Rear Left - Blue/Red
Rear Right + White/Blue
Rear Right - Blue/Black
Hope this helps
Post by El_Freddo » Sat Mar 11, 2017 11:44 am
You've tapped into the radio illumination wire which only works when the parkers or headlights are on. Did you check wire voltages with the headlights on?
All the wires you need should be in the stez plug with exception to permanent power which can be sourced from the clock or a new wire to the fuse box (with it's own fuse of course!).
All the best with it.
Return to “Sound / Entertainment Systems”
