BRUMBY REAR DISC's
Gazza01
BRUMBY REAR DISC's
Post by Gazza01 » Sun Jan 22, 2017 11:30 am
I have everything to set up my brumby with rear Disc's except rear Rotors . My question is Do I use Vortex rear Rotors RDA7554 or the front Vortex/Brumby Rotors RDA640.
Post by TOONGA » Sun Jan 22, 2017 1:08 pm
You can only use the vortex or RX rear discs as the front discs will not fit between the calipers when the pads are in place. I don't think the front discs will bolt to the rear hubs for that matter.
Gazza01
Post by Gazza01 » Sun Jan 22, 2017 5:29 pm
Thanks Toonga I have everything else but suddenly started looking for the rear disc's and realised I didn't have then. I been on ebay and see I can get RDA7554 Vortex Discs. Just got make sure they are right ones. Thanks lot anyway.
Post by El_Freddo » Sun Jan 22, 2017 11:38 pm
The rear discs are solid, not ventilated like the fronts.
As Toonga said, it's RX turbo or Vortex rear disc rotors you need. Since you've got the hubs (the hard bit to get), you can use the rotors from a 2wd vortex ;)
Post by Bantum » Thu Jan 26, 2017 7:01 am
I'm thinking you mean what are the differences between FWD & 4WD rear disc ? ... none - It has the same part number, only the hub is different.
Rear Disc : ( 2WD & 4WD )
Found Here : https://www.carid.com/1992-subaru-loyal ... 64502.html
As for the ability for the front rotor to fit on rear - nope, mount / size is all different ... :(
Front Disc :
More info : https://www.carid.com/1992-subaru-loyal ... 75361.html
Edit : Deleted the old image, replaced with the one I was looking for ...
Cheers, Bantum ...
Post by El_Freddo » Thu Jan 26, 2017 8:21 am
Bantum wrote: Image
Above is the 4wd rear disc hub required for this conversion for 4wd MY and L series Subarus. It's not the same size shaft as the front axle so a front hub won't fit.
Post by Bantum » Thu Jan 26, 2017 8:56 am
Doh - you beat me to it ( stupid computer - let me fix it )
Yeah the rear disc - it's the same, just the hubs are different.
Cheers, Bantum ...
dfoyl
Post by dfoyl » Thu Jan 26, 2017 5:44 pm
Anyone here looking for a set of rear discs ? I have a line on a set (possibly excluding the rotors, which would cost a fair bit to ship from the US) for around $160 US plus shipping from the US to you. I sold the last set I found on USMB but if anyone here wants them let me know.
