EJ engine/gearbox bolts - starter bolt
Post by El_Freddo » Sun Aug 14, 2016 9:19 pm
G'day,
I'm after four EJ engine/gearbox bolts for the Starter side only.
Reason being that I need to get my engine onto an engine stand and the starter bolt measures up to be long enough for what I need and are the same thread as the lower studs (which will be removed for this exercise). I currently don't have time to visit a parts yard where I can grab them from 4 vehicles (too far to go and local parts yards don't have any subarus - what's up with that??).
If anyone has a bolt that I could borrow or purchase please drop a line here or PM me.
dfoyl
Post by dfoyl » Tue Aug 16, 2016 3:01 pm
Bennie, I can help you out with these no problem. If you could PM me a photo showing exactly where the bolts are located I can pull them from PAP Kilsyth for you by the weekend.
Post by El_Freddo » Wed Aug 17, 2016 7:40 am
G'day Dfoyl,
Your PM inbox is full, so I thought I'd drop this in here instead ;)
I'm after four of the bolts in this location:
You'll find it hiding under the heater hoses, where the earth cable bolts to the gearbox/engine bolt at the starter motor (generally):
You'll need a 14mm spanner/socket must be EJ specific - otherwise It won't work!
Clear some PM space, shoot me one and we'll workout cost/postage etc
Return to “Wanted”
