Brumby/L Series Carby's
Gazza01
Post by Gazza01 » Tue Mar 08, 2016 6:41 am
Can anyone tell me if the L Series Carby will fit and work ok on a Brumby motor.
Proton mouse
Post by Proton mouse » Tue Mar 08, 2016 12:04 pm
Not a direct fit. You would first need a non feedback carb and its manifold, then some grinding and moving of coolant lines is required.
JB
Gazza01
Post by Gazza01 » Wed Mar 09, 2016 10:54 am
Thanks for info I managed to get a Brumby Carby .
Post by steptoe » Fri Mar 11, 2016 7:54 am
anyone else reading this, could go the whole EA82 carb and manifold to save fiddling to get L carb on EA81 inlet and use EA82 top hose. I run EA82 inlet manifold on my EA81 in a Brumby
Post by El_Freddo » Fri Mar 11, 2016 4:37 pm
steptoe wrote:anyone else reading this, could go the whole EA82 carb and manifold to save fiddling to get L carb on EA81 inlet and use EA82 top hose. I run EA82 inlet manifold on my EA81 in a Brumby
That works well unless you're running Power steering - coolant hose has to go through the PS belt...
Post by TOONGA » Fri Mar 11, 2016 5:21 pm
Use the EA82 PS Pump :) The turbocharged Jap EA81 used a similar unit
Post by TOONGA » Fri Mar 11, 2016 5:22 pm
El_Freddo wrote:That works well unless you're running Power steering - coolant hose has to go through the PS belt...
Use the EA82 PS Pump :) The turbocharged Jap EA81 used a similar unit.
Proton mouse
Post by Proton mouse » Fri Mar 11, 2016 5:44 pm
Said that!! Just forgot about the hose bit ☺
Post by El_Freddo » Sat Mar 12, 2016 12:48 pm
TOONGA wrote:Use the EA82 PS Pump :) The turbocharged Jap EA81 used a similar unit.
I've never seen this done without the turbo bracket and crank pulley. It'd be interesting to see if it would work.
coxy
Post by coxy » Sun Mar 13, 2016 8:28 pm
This will do it so it is possible
EA82 power steer pump to EA81 kit.jpg (55.79 KiB) Viewed 7037 times
Post by El_Freddo » Sun Mar 13, 2016 8:48 pm
Does this work with AC? And where do you get this kit from?
coxy
Post by coxy » Tue Mar 15, 2016 9:08 pm
Kit comes from one of the USMB members where I have been banned for some crock reason related to spam (Spare me the BS)
I am borrowing the idea for my Brumby and seeing as I have full fabrication equipment going to make one for myself and yes I have just picked up MY Factory Air for a bargain Hundred dollars so I will make sure it works with AC.
Busy with new Job but will sort it out over the next few months or so and keep you in the loop, May as well make a few after I sort out the prototype.
