Melted tail light - that could have been much worse
Fitted additional tail lights so lighting could still be considered OK with the spare wheel on the rear.
Cracked the left one ages ago and didnt worry about it till the stop lamp light came on the dash.
Good grief it stank and still does when I cracked it open.
Lucky I didnt burn something out.
No fuses blew either.
[img][IMG]http://i1189.photobucket.com/albums/z43 ... G_6388.jpg[/img][/IMG]
Right hand side
[img][IMG]http://i1189.photobucket.com/albums/z43 ... G_6405.jpg[/img][/IMG]
Left hand side
[img][IMG]http://i1189.photobucket.com/albums/z43 ... G_6409.jpg[/img][/IMG]
Left hand side melted after market additional tail light.
Right hand side
Left hand side
I guess I bumped the light about a year or so ago which caused a crack in the top of the indicator lens section where water entered the sealed light.
As the light is sealed it has to be broken open to gain entry.
When I broke it open a heap of water came out and it stank of burnt components and I still cant get the smell off my hands.
I cut the light off and tossed it in the bin but did note there was a big burnt bubble of plastic on the rear of the light where things were going south in the back of the stop lamp part.
Still insane! I've got a set of cheapie LED auxiliary rear lights on the back of Ruby Scoo - only installed them last year and hard wired them in thinking if there's an issue the factory fuse will blow. Now I'm thinking otherwise.
I guess you'd need a rather small fuse with the LEDs to get it to pop when there's an issue...
