Ea 81 motor will start then stops
gtcompletepower
Post by gtcompletepower » Tue Jan 26, 2016 2:37 pm
Have an ea81 in a Brumby when I turn the key to the start position the car will run as soon as I let it go back to the on position it stops what's the problem
gtcompletepower
Post by gtcompletepower » Tue Jan 26, 2016 3:01 pm
Update it will run if I run power directly to coil.where do I start looking?
Post by TOONGA » Tue Jan 26, 2016 3:10 pm
Fuses ... then check to see if there is power at the on position of the ignition barrel.
As well check the wiring to the coil for power in the on position.
is it points or electronic ignition?
If points check the ballast resistor to see if it is broken
gtcompletepower
Post by gtcompletepower » Tue Jan 26, 2016 6:23 pm
Found it it was the fuse thanks
Post by TOONGA » Wed Jan 27, 2016 8:27 am
gtcompletepower wrote:Found it it was the fuse thanks
Not a problem it is even more fun when that happens on a bridge in traffic :)
I spent 10 minutes on the side of the road trying to work out why.
turned out I had a loose wire on the electric choke and it was shorting the fuse.
