L series Wagon with Full Time 4WD, Handling??
Just wondering if you guys with full time boxes fitted could tell me how an L wagon handles with one in, on the road. Does it under-steer when pushed? How much? Does it over-steer at all? Be nice if it did.
I've got a full time box and I'm not sure if I want it in my road car or not, it's part time at the moment.
Is there any way to mod/change a centre diff in one of these boxes to give it a rear bias?
Any one ever tried dropping out the front drive shafts on a part time, and running an L as RWD?
Thanks
Thanks
- Chris_Rogers
- Suby Wan Kenobi
- Chris_Rogers
- Chris_Rogers
- Ben
Re: L series Wagon with Full Time 4WD, Handling??
I had an RX with AWD, so LSD and rear swaybar. Had enough power to spin a front inside tyre through corners. Enough power to spin the rears by pulling the handbrake on and dumping the clutch. Only difference the awd made to handling was rather than spinning hard enough to make smoke on tight corners it would just spin a little - I guess it was quicker in that respect. L series handle shit anyway.dree wrote:Just wondering if you guys with full time boxes fitted could tell me how an L wagon handles with one in, on the road. Does it under-steer when pushed? How much? Does it over-steer at all? Be nice if it did.
Whack it in, even marginally better is better, they just bolt in with minor mods to the selector (cut rotate and weld). Get some AC Vacuum solenoids to operate the diff-lock.dree wrote: I've got a full time box and I'm not sure if I want it in my road car or not, it's part time at the moment.
Yes, anything is possible. The mechanical centre gives infinite variation between front and rear. You should be able to shim it to bias the rear. Though it'll be noisy and wear fast.dree wrote: Is there any way to mod/change a centre diff in one of these boxes to give it a rear bias?
I haven't but others have. No advantage is to be gained in doing it.dree wrote: Any one ever tried dropping out the front drive shafts on a part time, and running an L as RWD?
Thanks
Listen to what Chris has to say, he knows.
