89 L series auto box in need of a front diff
Post by El_Freddo » Mon Sep 28, 2015 10:50 am
Item............................... 1989 L series GL auto gearbox in need of a front diff
Description/Condition...................... The rear bearing on the pinion shaft has been starved of oil and collapsed, this has allowed the pinion shaft to move forward and damage/lock onto the diff centre. Pinion and crown wheel look to be in good condition.
The Auto itself worked very well and the 4wd coupling was tight when used on dirt (very rarely). Some water found in oil due to sitting outside - it has not been run with oil in it.
All shafts seem to be in good condition.
Torque converter included, now needs a clean up as it's rusty.
Location ..........................Cobaw VIC
Price................................ $30
Contact ............................ Here or via PM.
Dead pinion bearing:
Some scraping of the main casing front the pinion shaft, the seal seat is not damaged:
Post by steptoe » Mon Sep 28, 2015 11:07 pm
hmm, so is it a 3.45:1 front diff . like the one that was in my 85 build 3 speed 4WD auto had ?
Once a gain nice clear pics - really stand out !
Post by El_Freddo » Wed Oct 14, 2015 11:06 pm
I'll check it out when I'm near that box again ;)
I didn't count teeth the last time I was near it...
