The other new inner and outer CV boots are for a spare front drive shaft that I am hoping is still OK and is suitable for a working spare.
Upcoming work on the MY
Well, I would rather be driving the MY instead of rebuilding 2 x front CV's and 2 x front wheel bearings but I guess that's the way it is with 1 x busted inner CV boot (may as well replace all of them on both sides) and a leaking inner wheel bearing seal (may as well replace all of them too on both sides).
- Silverbullet
I am yet to find a need for a press for MY front bearing or shaft install/ removal and wondering what I am doing wrong .....I tap the outer end of shaft to extract from bearings and may need to thump shaft on solid ground and weight of hub finds its way onto the bearings, with a final nip at the end with big nut and is done. A tambox tip is lots of kitchen paper towel for the cv boot grease clean up
- mrwalker500
Getting them out is relatively easy with a socket extension or similar and a soft face hammer ensuring to tap evenly around the ring of the bearing. A press makes putting them in a lot easier. I just went to my local garage and they pointed me in the direction of the pre WW2 manual press. Too easy!
Sent from my iPhone using Tapatalk
Wife, 'Oh that's nice, it can be our sons first car'
Me, 'Yes I will make it strong and safe' ...and fast, but there is no way a 17 year old is going to drive it.
Today, I finally finished fitting everything.
One thing though, the grease in the front LH bearings was basically black ?
I always use the basic high temp bearing grease and the RH side was Ok but I changed the bearings and seals anyway.
The front drive shafts are thought to be original (certainly there in 98 when we bought the car) but the RH side had developed the infamous "clacking" so dug around and found a spare drive shaft with CV's I had. Fitted the new boots with grease and all good.
I now recall why I don't like degreasing, re greasing and fitting CV boots.
Crap job to do.
Crap job to do.
I did get a CV boot banding tool BUT, out of all the 6 boots only 1 band was long enough to go around the boot twice (I like it this way) so I drilled 2 more holes further down the tool towards the tip to hold the slotted spindle that grips the end of the band. I totally agree that when the tool is used ALL of the mental strain of getting the band tight without stabbing a hole into the side of the new boot is gone. So quick too.
