Can anyone confirm if inner and outer bearings and seals for each side of an MY (1982 if it makes any difference) are the same or not.
I pulled the front LH drive shaft out today as the inner CV boot is split and I see the inner bearing seal is leaking.
I pulled both the inner and outer seals off and the seals look the same but as I haven't measured where the seals seat on the drive shaft and the inner diameter of the front hub I am not sure.
MY front drive shaft seals & bearings
- Silverbullet
