MY/Brumby bouncing speedo needle
G'day all,
So Sunnie the Brumby's speedo now flickers/bounces/wobbles. The fast you go the worse it gets. It bounces about 5mm with your actual speed in the centre of that.
My question is: would this be speedo cable related or speedo drive gear related? Or worst yet the speedo head itself?
Any help or insight into this would be greatly appreciated!
I reckon you've nailed it on the head Johnno!
I drive Sunnie between Shepp and Benders only to realise halfway through the trip that the needle was very steady. Slow down to 60 and there's a bit of a wiggle but not as bad as I e seen it.
Your comment about cold made me realise I've seen the wobble/bounce at its worst on the way to work - cold run, no pre warm up.
I'll have to get on that. I'm guessing its "just a squirt" of that stuff, not a 2 sec spray hold amount?
